I am trying to find out which headers fit a 1990 Caprice 9C1. But the issue I might have is I am looking for (1.75) 1-3/4 headers due to the fact I want to run a 400 plus inch small block engine. I don't think that 1.625 (1-5/
or 1.5 (1-1/2) inch primary set will be able to flow enough to run the engine even to 5000 RPM. Let alone 5800 or higher. I don't care if it would be shortie, mid-length or long tube. Then I'll worry about the rest of the exhaust later.
Does any set from an early Chevelle fit or older Impala? I have heard the 73 to 75 Chevelle Big Block headers would fit a Big Block conversion but would the same year Small Block ones work?
