    1985 roller cam/lifters or 1984 flat tappet?
    farrellapparel
    farrellapparel
    1985 roller cam/lifters or 1984 flat tappet? Empty 1985 roller cam/lifters or 1984 flat tappet?
    Post  farrellapparel Sat May 12, 2018 1:39 am
    Hi, I have a 1984 Buick w/ 307. I can get a 1985 engine complete for $100. Is it worth buying and using the roller lifters?
    Thanks,
    John
    1985 roller cam/lifters or 1984 flat tappet? Empty roller cam
    Post  terry cronk Sun May 13, 2018 10:56 am
    Is that 1985 307 engine an Oldsmobile engine?
    If so you will have almost twice as much in it being built as a Chevy 350 or a 383 stroker.
    They can be made to run, but expensive to do.
    Good luck!   Rolling Eyes
    350Rocket
    1985 roller cam/lifters or 1984 flat tappet? Empty Re: 1985 roller cam/lifters or 1984 flat tappet?
    Post  350Rocket Wed May 23, 2018 1:53 pm
    The older one works a lot better. The roller cam 85+ have different heads with tiny ports. I've also personally owned and driven a few of both and the 84 and older has way more torque off the line.
      Current date/time is Sun Dec 03, 2023 6:40 pm
