    79 Olds delta88
    Oldsragger
    Oldsragger
    79 Olds delta88 Empty 79 Olds delta88
    Post  Oldsragger Wed Feb 21, 2018 5:51 am
    Hello, im 33yr old and here is a little story of my car and what i have done for now..
    *Rescue it from a friend maybe 5 years ago.
    *Have been 12 owners before me.
    *Original royale blue metallic,have been lightblue,black matt, and now, rusty red..
    *When i got it home i rebuild the 800cfm q-jet carb,because it was full of dirt,rebuild the gastank.
    *Fixed up the rust with much welding around,change chassis parts and with upgrades,built crossmember for dual exhaust,  swapped out the small v8 with a rebuilded and upgraded bb engine.
    *Headers
    *Now the th350 tranny is dead,  rebuilding a th375 tranny (basic a th400) but with 350 outputshaft.
    *8x15 4"bs front with 245/60.  and Rear 10x15" rebuild from 4 to 5"bs to get the 295/50 tires inside the fender.
    *New controllarms in front, polyrethan bushings around.
    *New lower controllarms rear,swapped out the old upgraded controllarms with homemade POM bushings and welded brackets ,same with upper arms, and with some gbody polyrethan axlehousing bushings.
    *I want to replace the body/frame bushings but cant find anything yet.
    *Swapped out the front spindels with a Chevy station wagon and 1LE Brakediscs from camaro to keep the 4x4,75" pattern..
    *Replaced rearbumper with a rebuild one.
    *New doorseals for window seal
    *New HD frontsprings
    *Right now im building a Th tranny stand.
    much more to write and have many pictures about what have happend to the car but it is a beginning..Hope the pictures work.
    79 Olds delta88 L7XRZx
    79 Olds delta88 V9IyXC
    79 Olds delta88 4zsoaq
    79 Olds delta88 QmZyFT
    79 Olds delta88 CwRLFE
    79 Olds delta88 Suwwep
    79 Olds delta88 Empty Re: 79 Olds delta88
    Post  GM B-Body Forum Fri Mar 02, 2018 2:52 pm
    Nice man! I love it, keep us updated as you go along! Welcome to the forum.
    Sent from Topic'it App
      Current date/time is Tue Mar 21, 2023 10:17 am
