    Body mounts
    Body mounts Empty Body mounts
    Post  terry cronk Mon Oct 09, 2017 10:13 am
    Does anyone have a number for universal mounts that fit my 79 Caprice?
    JC Whitney has some but until I pull the old ones, I'm not sure which are the right ones.
    Anyone replace theirs?
    78i6belair
    78i6belair
    Body mounts Empty Re: Body mounts
    Post  78i6belair Tue Oct 10, 2017 8:36 am
    Hi there.
    From the information that I've gathered, There are no direct replacements available for the 1977-96 B cars and wagons. I could be wrong here.
    I'd look and see if you can locate body mounts for a 1973-77 GM midsize A body and the 1977-93 C body cars.
    Post  Kit1078 Tue Oct 10, 2017 8:29 pm
    I used the Energy Suspension kit for a 91-96 B body, the light duty version. The light duty version does not have all the captured lower bushings like my '77 had, but I had enough good ones left over from the original bushings that I was ok. They did not come with washers or sleeves, tho, so if those are rusted out, you're kinda up a creek.
    Post  terry cronk Fri Oct 13, 2017 4:00 pm
    Washers and sleeves can be gotten. The good poly bushing is the issue. Even stock new would be better.
    alusil850
    alusil850
    Body mounts Empty 77-79
    Post  alusil850 Sat Nov 04, 2017 5:12 pm
    hi,
    old post but some news for it.
    after a long time without oem part available, this body mount from dorman look to do the job,
    is ref is:
    DEA/MRC A2714
    I order it for 3$ each on rockauto.
    but if anybody know the location of original bodymount, all are differents, and I don't find logic, soft, hard, with or without lateral handling...
    Gooched78Caprice
    Gooched78Caprice
    Body mounts Empty Complete 1977-1990 B-Body Body Mount Bushings with Steel Sleeve Inserts $249
    Post  Gooched78Caprice Sun Nov 05, 2017 1:02 pm
    https://www.thepartsplaceinc.com/home.aspx
    Part # HB10531P
    I don't see the very front radiator mounts with this kit but the rest of the Body Bushings are there.
    I did about 6 months of weighing +/- about replacing my bushings with energy suspension poly bushings since I couldnt find the a direct specific set like these anywhere and of course a few weeks after taking the plunge on Energy Suspension these came out.
    Extra Bonus* If you are also in need of the metal inserts for the body bushings with these <40 year old cars this will save you a bunch of time versus trying to amass a set out of the junk yard and none of the Energy kits supply them.
    Body mounts Empty body mounts
    Post  terry cronk Thu Nov 09, 2017 4:39 pm
    Thanks for the information.
    That's $249.00 for all 22 mounts.
      Current date/time is Tue Mar 21, 2023 10:09 am
