    95 Caprice wanders during acceleration in the rear. HELP!
    GmGuy80
    95 Caprice wanders during acceleration in the rear. HELP! Empty 95 Caprice wanders during acceleration in the rear. HELP!
    Post  GmGuy80 Wed Aug 30, 2017 5:45 pm
    I recently purchased the car with 108K for only $500, its in Chicago so obviously it needs some attention to rust but runs great. The problem Im having is that when I press the gas pedal, the rear end sways to the side. I noticed today that the rear wheels point inward quite a bit.. enough to really notice. While the car is driving down the street, it feels perfect until i press the gas and when I let off. confused
    Fierro51
    Fierro51
    Sophomore Member (Tier 4)
    95 Caprice wanders during acceleration in the rear. HELP! Empty Re: 95 Caprice wanders during acceleration in the rear. HELP!
    Post  Fierro51 Thu Aug 31, 2017 4:45 pm
    need to put it up on jack stands and check the rear 4 link bars/bushing could be shot or one of the bars could be broken/bent
    Post  Kit1078 Tue Sep 05, 2017 1:43 pm
    Definitely check your rear control arm bushings and the rear upper control arms. that sounds like a bad control arm or bushing, and these cars are known for not having the strongest upper control arms in the rear.
    GmGuy80
    Post  GmGuy80 Fri Sep 08, 2017 6:09 pm
    Thanks guys! I checked and the rear drivers side lower control arm bushings were completely worn. I was able easily move it by hand.
    Fierro51
    Fierro51
    Post  Fierro51 Tue Oct 31, 2017 10:31 am
    glad to hear you got it fixed
      Current date/time is Thu Mar 30, 2023 4:31 pm
