    2004R speedo chart?
    2004R speedo chart? Empty 2004R speedo chart?
    Post  terry cronk Sun May 21, 2017 7:00 pm
    Anyone have a link to a chart showing what gears to use in the 2004R transmission speedo?    Smile
    I have all I need for th.350/700R4.
    2004R speedo chart? Empty Re: 2004R speedo chart?
    Post  GM B-Body Forum Mon May 22, 2017 7:43 am
    You're talking about the little nylon gears right? I was going to say I havent seen much for the 2004R. Ill see if I can find something.
    2004R speedo chart? Empty 2004r speedo
    Post  terry cronk Mon May 22, 2017 7:57 am
    Yes the drive/driven gears.
    I have a supplier that gave me the information as to which gears to use.
    But I want the chart to show all combinations.
    I'd appreciate the info.
    2004R speedo chart? Empty 2004R speedo gears
    Post  terry cronk Mon May 22, 2017 8:29 am
    I found this chart to go by.
    http://www.montess.org/speedo_gears.html
    His discussion is about his Monte Carlo. But a lot is attributed to our "B" body needs.
    Have a good one.
    2004R speedo chart? Empty 700R4
    Post  terry cronk Mon May 22, 2017 4:48 pm
    Well I ended up and put money down on a 700R4 for heavy duty rebuild.
    Mid-Michigan Transmission will be building it.  Tony Martin builds them tough. He is out of Kawkawlin, Michigan.
    A local car show guy has a 468 BBC in a 1968 short box pickup and has not had any problems.
    I had a long talk with him today earlier on the phone and then when I went to his shop.
    He seems very knowledgeable about the needs.  So we will see in a week or so.
    It will have an 1800-2200 rpm stall convertor included.   All for around $1000.00.
    That stall is enough for the XE268 Comps cam w/3.73 gears and 275x60x15 tires.
    Now to take out the old 305 and 350 transmission.   tongue
      Current date/time is Fri Mar 31, 2023 5:51 pm
