    Turbo 350 rebuild
    Turbo 350 rebuild Empty Turbo 350 rebuild
    Post  terry cronk Tue May 16, 2017 9:04 am
    I pulled the turbo 350 in, dismantled it, cleaned and ordered rebuild kit.   Direct clutch had only 4 clutches.
    Measured the piston, took off .110 off the face for additional clutch and steel.  I used the forward pressure plate(thinner) in order to allow .030-.035 clearance.
    Then I machined off about .045(thicker plate) off the forward piston for proper clearance.  Ended up with 5 and 5 in both clutch packs.
    Alto red clutches and Kolene steels.  Before buying a kit ask to make sure there is a total of 10 clutches and 10 steels in the kit.
    I installed a Fairbanks shift kit for street/strip.   Also a new hardened intermediate sprag.  A 700R4 lower case support with the larger roller and new roller cage.
    It is about 50% more holding power.  Fits right in.  Also purchased a Boss Hog stall convertor that's 1800-2200 rpm stall.
    Also installed is the larger diameter cable drive with the correct gears for my speedo.
    When I get it all in, I'll report back on how things are going.
    Love this warmer weather.
    Three pictures
    The 2 extra quart pan.  No extension on filter needed.
    Turbo 350 rebuild P1010014
    Fairbanks kit number(upside down)
    Turbo 350 rebuild P1010017
    The Alto clutches and Kolene hardened steels
    Turbo 350 rebuild P1010018
    Turbo 350 rebuild Empty Re: Turbo 350 rebuild
    Post  HeavyChevy77 Wed May 17, 2017 3:04 pm
    Nice work bro got the th200 that's still holding on but wanna get a 4 speed preferable the th2004r but a th350 is cheaper and more readily available
    Reason for the th2004r is more gears for lower freeway rpm better mpg and not to mention more gears to rip through
    I was thinking bout going with a gear splitter to make that 3 speed a 6 speed essentially. Wanted to know what you (and other here) think know or heard about that.
    Turbo 350 rebuild Empty 350 rebuild
    Post  terry cronk Wed May 17, 2017 4:18 pm
    The split gearing is a more complicated avenue. Adding a gear box attached to your output.
    The only one that I know of is Gear Vendors that sells an attachable unit. With a choice of ratio to go to for O.D..
    Other than that the 700R4 is a good choice that's 1984-1987 that's NOT ECU (electronic control unit).
    Getting harder to find lately. Not crazy about the gear ratio.
    The 2004R is nice, but more costly to build up to last. I love the gear ratio. But we can't have our cake and eat it too.
    Good luck. Let us know how you come out.
      Current date/time is Fri Mar 31, 2023 6:17 pm
