    Front Brake line from master cylinder to combination valve
    dcving
    Front Brake line from master cylinder to combination valve Empty Front Brake line from master cylinder to combination valve
    Post  dcving Thu Apr 06, 2017 2:13 pm
    hi, i have a 1986 parisienne and i just replaced my master cylinder when the front line that comes out of the master cylinder cracked where it goes under the body into the combonation valve...the car is a few hours away and i would like to order a new brake line to be the proper size and i was wondering if any of you knew the fitting sizes and hose lengths...or even if i could run a stainless braided line or rubber?
    thanks alot
      Current date/time is Sun Dec 03, 2023 7:32 pm
