    How to convert 79 delta 88 to 5x5 front bolt circle
    jboehm
    How to convert 79 delta 88 to 5x5 front bolt circle Empty How to convert 79 delta 88 to 5x5 front bolt circle
    Post  jboehm Thu Aug 04, 2016 2:40 pm
    On this 1979 delta 88 the rear was swapped to a 5inch bolt circle years ago, but the front is still the smaller 4.75. What is the easiest and cheapest way to get the 5x5 pattern. No spacers are not an option with the wheel I want to use. Is there a standard rotor that can be used with my current spindle?
    How to convert 79 delta 88 to 5x5 front bolt circle Empty Re: How to convert 79 delta 88 to 5x5 front bolt circle
    Post  Sweet Seventy9 Fri Aug 05, 2016 12:32 pm
    The only way I'm aware of to get the 5x5 pattern is to upgrade your spindles and brakes to the larger 12" setup. There's a write-up on how to do it on here somewhere that includes part numbers.
    Boogie1468
    How to convert 79 delta 88 to 5x5 front bolt circle Empty 5 x 5 bolt circle front bake rotor
    Post  Boogie1468 Wed Aug 24, 2016 5:55 pm
    I think any 1991-96 Caprice front rotor assembly will fit on your spindles. They are identical to the 77-90 but with 5 x 5 not 5 x 4.75.
      Current date/time is Fri Mar 31, 2023 6:11 pm
