    Fuel delivery
    GEOLANG1
    Fuel delivery  Empty Fuel delivery
    Post  GEOLANG1 Sun Jul 24, 2016 10:51 pm
    Forum,
    I have an issue with my 79 Caprice. When it sit over night or for a few hours, it won't start without priming the carburetor. I've changed the carb, fuel pump and fuel lines. I don't see any leaks anywhere nor do I smell fuel. Once I do get it started, it runs fine but after it sits for a long period of time, it does the same thing. Don't know what else to do
    Fuel delivery  Empty Re: Fuel delivery
    Post  terry cronk Mon Jul 25, 2016 1:59 pm
    Make sure the choke is working.
    Post  HeavyChevy77 Mon Jul 25, 2016 5:32 pm
    Probably heat soak dam ethanol fuels are more volatile and expand more than regular  fuel pushing fuel past the idle screw eventually flooding it hence hard start
    Use a 1" plastic spacer or 1/2" wood spacer too keep fuel cooler one been meaning to try that startron fuel additive but haven't yet heard it works good
      Current date/time is Fri Mar 31, 2023 6:52 pm
