I have a 78 Buick LeSabre Coupe. I plan to go the pro touring route with ls t56 swap, Speedtech suspension and Kore3 brakes. Right now I'm trying to find spindles. Will 70-81 F body spindles work on the b body?
+3
Xtreme Thunder
vwmopar
7 posters
Spindle interchange
vwmopar- Active Member (Tier 2)
Spindle interchange
Re: Spindle interchange
I guess no one knows anything.
Xtreme Thunder- Active Member (Tier 2)
From what I gather the 2nd Gen GM F-Body guys used to use GM B-Body spindles as a modification to allow for the larger rotors. You may be better off sourcing GM B-Body spindles if you are looking for larger brake rotors than what the 2nd Gen GM F-Body originally came equipped.
I'd contact KORE3, as I did a few weeks ago myself, and they were extremely helpful as they don't specifically list the GM B-Body, in my case a '87 Caprice, on their site. Let them know what you are looking to do and go from there.
I know not directly answering your question, but that is what I came across in my brake upgrade research.
Thank you. That's probably what I'll do. What info I find I'll post.
Or contact speedtech which I have with no answer.
Kit1078- Freshman Member (Tier 3)
My understanding on Spindle interchange is:
70-81 F body
74-77 A body (Monte carlo, grand prix)
77-90 B Body
The 77-96 B body with 12" spindle has been used as a swap for F bodies to get the 12" brakes. If you use a 88-90 1LE camaro rotor on the 12" B body spindle, you maintain the 5 x 4.75" bolt pattern.
I picked up a set of spindles from Classic Performance Parts that are cast to use a C5 corvette bearing and brakes. They're cast iron, stock geometry, just retooled to accept the corvette brakes. Link posted below:
https://www.summitracing.com/oh/parts/clp-7081swbksc5r/overview/
70-81 F body
77-90 B Body
Awesome thanks
I know they used to do the same with A-bodies, switching over to B-body spindles and brakes, and control arms. People like our braking systems!
- Post n°9
Is it the brakes or the spindles? I've heard of guys doing tall spindle swaps on some cars just haven't found any specifics on it.
- Post n°10
I can't find any by me in the yards though they rarely get B bodies anymore. I may have to go for dropped spindles that's
all they seem to make now. I really want to swap my front brakes badly they burn going down steep inclines, these are the 11"
with the larger pads.
- Post n°11
gotta watch your wheels with drop spindles. a lot of Impala SS guys have trouble with the steering arm on the spindle hitting the inside of the wheel with 2" drop spindles. if I can find the link to the pics one guy had, i'll post it.
Kore3's GM Tall spindle kit will fit a B body spindle, you just have to watch, there's two versions based on wheel bolt circle and bearing type.
docolds1- Newbie (Tier 1)
- Post n°12
Kit1078 wrote:My understanding on Spindle interchange is:
70-81 F body
77-90 B Body
How did this kit work out for you? I'm looking to do the same.
- Post n°13
docolds1 wrote:How did this kit work out for you? I'm looking to do the same.
I haven't gotten it on the car yet, I just got done doing bushings in the front end and need to clean up the steering gear before I put it all back together. They're decently built, and though they're cast iron, they're still a bit lighter than the stock spindles once assembled. If I ever post a build thread I'll put pics of them there.
- Post n°14
I haven't tried it yet. I'm doing research. I won't be running dropped spindles. Going to use Speedtech suspension which will give around 2 inches of drop.
78Cupeprice- Newbie (Tier 1)
- Post n°15
Hi Kit1078
Im thinking of buying the CPP F body spindles same as you. Have you had a chance to Install them? Im wondering if you came across any issues?
- Post n°16
I've installed the CPP spindles. I can't post pictures for some reason, but they fit ok. A few notes: I didn't like the allen head socket screws they use to hold this wheel hub on, so I sourced some stock GM hub bolts from the junkyard. The calipers aren't actually 'corvette' calipers, they look more like knockoff. If I were to do it again, I'd just buy the bare spindle, and source the wheel hubs, rotors, calipers and brake pads. I didn't bother trying to weigh them compared to the original, but my arm scale says they're a little bit lighter. I can't say much for stopping power, I'm still dialing in the brakes. I did a manual brake conversion and I'm having some teething issues with that.
