Introduction
BrokenBlazerDave- Active Member (Tier 2)
Introduction
Re: Introduction
Nice run, great to see a smoking fast B Body !
Re: Introduction
Re: Introduction
Nice job clean and to the point!
Re: Introduction
I like your buckets combination.
Let alone how it runs down the track.
What all is done to the car. Gears, Transmission etc.
Thanks for the vid.
Thanks for the vid.
Re: Introduction
It is a 350 that is bored over .030”. It has an Eagle crank and rods, SRP pistons, Comp solid flat lifters and cam(260/260@.050”,.555 lift), ported and polished Edelbrock RPM heads, Edelbrock single plane intake, 750 Holley HP carb, 3800 stall, TH350, 4.56:1 gears and Progressive nitrous controller(usually 100HP but I have tried 250HP). The engine is 17 years old now I have considered new parts and new technology but it works too good to take apart.
Re: Introduction
That's a lot of power and a great ET. for a B-Body.
Its well set up. Are you running a 3 speed auto.?
I like what you did with the dash, Tach. and gauges.
I have looked at mine to customize as well.
Thanks.
Thanks.
Re: Introduction
It is a three speed turbo 350.
