    295 tire on a 10 inch wheel
    bossbox
    295 tire on a 10 inch wheel Empty 295 tire on a 10 inch wheel
    Post  bossbox Mon May 02, 2016 7:47 am
    Anybody have a caprice with a 295 tire on the rear? If so post some pics. Thanks
    295 tire on a 10 inch wheel Empty Re: 295 tire on a 10 inch wheel
    Post  Sweet Seventy9 Mon May 02, 2016 11:30 am
    bossbox wrote:Anybody have a caprice with a 295 tire on the rear? If so post some pics. Thanks
    15x10 wheels, 295-50/15 tires on the rear.
    295 tire on a 10 inch wheel 0000-m10
    295 tire on a 10 inch wheel 11074210
    295 tire on a 10 inch wheel 11074211
    295 tire on a 10 inch wheel Mvc-7910
    295 tire on a 10 inch wheel Mvc-8010
    295 tire on a 10 inch wheel Mvc-8011
    bossbox
    Post  bossbox Mon May 02, 2016 11:51 am
    Nice! Whats the back spacing on those wheels?
    bossbox
    Post  bossbox Mon May 02, 2016 12:36 pm
    Thats a very clean car bro! I see our cars fit those 295s with ease.
    Post  Myloth Mon May 02, 2016 12:44 pm
    I believe 4.5" this pic here has a 1" spacer on it do to the rearend being 5x5 bolt pattern
    so they stick out a tad more. I'd measure them but it's raining right now.
    295 tire on a 10 inch wheel Imp110
    It's a good fit either way I bet you could fit 15x11 with 305s on these B Bodies
    Post  Sweet Seventy9 Mon May 02, 2016 12:54 pm
    bossbox wrote:Nice! Whats the back spacing on those wheels?
    5" back spacing, zero offset. They're made by Wheel Vintiques. I wanted to use Rally wheels, only wider.
    http://www.jegs.com/i/Wheel+Vintiques/939/30-503405/10002/-1
    For a little more $$, Paulsons Wheels makes them with a dual lug pattern, 5x5 and 5x4.75.
    bossbox
    Post  bossbox Mon May 02, 2016 12:59 pm
    Cool! I have 15x10 billet specialties street lites with 5.5 backspace. Im trying to tuck them in under the body as much as possible with a 295 50 15 tire.
    bossbox
    Post  bossbox Mon May 02, 2016 1:00 pm
    15x11 with a 305 would be nasty!
    Post  Sweet Seventy9 Mon May 02, 2016 1:02 pm
    315s fit too
    bossbox
    Post  bossbox Mon May 02, 2016 1:08 pm
    I would love to see a 315 on there.
    bossbox
    Post  bossbox Mon May 02, 2016 1:10 pm
    Did you have a spacer on in the first set of pics you sent?
    Post  Sweet Seventy9 Mon May 02, 2016 2:11 pm
    bossbox wrote:Did you have a spacer on in the first set of pics you sent?
    No spacers.  Myloth is using adapters to convert from 5x5 (axle) to 5x4.75 (wheel)
    295 tire on a 10 inch wheel Air1_011
    295 tire on a 10 inch wheel Air1_010
    295 tire on a 10 inch wheel Air1_012
    bossbox
    Post  bossbox Mon May 02, 2016 2:25 pm
    The adapter makes the wheel poke out slightly right?
    Post  Myloth Mon May 02, 2016 3:53 pm
    I like the look with the spacer, it's just in from the wheel well flare by 1/2 click
    if you had 315s with no spacer it would look like that I suspect.
    Also given the width of these cars 295s don't even look all that big.
    I had 245s on an 05' Impala and they looked about the same as
    the 295s on the 79'.
    Post  terry cronk Fri May 13, 2016 10:09 pm
    I am putting 275-60x15 on 8 inch rims. I have some concern. Maybe no need be.
    bossbox
    Post  bossbox Fri May 13, 2016 10:54 pm
    275 on an 8 inch wheel shouldn't be a problem at all.
    bossbox
    Post  bossbox Fri May 13, 2016 10:58 pm
    How do you post pics on here? Lol
    Post  Myloth Sat May 14, 2016 8:36 am
    Use the host image then copy the link it gives you for your picture into the post
    Greyghost
    Greyghost
    Post  Greyghost Thu Jun 09, 2016 1:03 pm
    315's dont look all to bad, ill post a picture either tonight or tomorrow, they dont seem to poke out as far as his 295's either
      Current date/time is Sun Dec 03, 2023 7:20 pm
