*the goose*
- Post n°76
Re: *the goose*
Is that the factory wiring harness?
Fierro51- Sophomore Member (Tier 4)
- Post n°77
Re: *the goose*
Yes sir. I found a guy in colorado that was making his own modified harnesses. That's why you see all the red wires
- Post n°78
Re: *the goose*
GM B-Body Forum wrote:Is that the factory wiring harness?
I'll post a better pic later today
- Post n°79
Re: *the goose*
What did the harness cost you?
- Post n°80
Re: *the goose*
500.Myloth wrote:What did the harness cost you?
but now fitech sells a "self learning" standalone harness for any ls swap application for 799 without trans control. which is way more bang for the buck
- Post n°81
Re: *the goose*
not bad for my first wrap job
headers are even now that its been cut down
- Post n°82
Re: *the goose*
might be going twin 66/73's
- Post n°83
Re: *the goose*
- Post n°84
Re: *the goose*
[img]
[/img]
got alot done this weekend. wired in the entire harness. starter wiring battery cables to the trunk and to the engine mounted the intake. installed the new injectors, spliced in new connectors and extended some electrical wiring as i routed the harness to the rear of the engine to the front which is opposite of oem.
still alot to clean up but it did start up for the first time and its a mean mother
- Post n°85
Re: *the goose*
Excellent progress a video of the engine running at some point would be cool.
- Post n°86
Re: *the goose*
Myloth wrote:Excellent progress a video of the engine running at some point would be cool.
yeah i have one i cant seem to get it to load up from PBhttps://vid306.photobucket.com/albums/nn280/superstroker10/First_start_1.mp4
- Post n°87
Re: *the goose*
https://2img.net/i/fa/pbucket.gif
order this one with the 4" core instead of the 3" should be here friday. now this weeks gonna drag on like crazy
- Post n°88
Re: *the goose*
hmmm links dont seem to be working
https://www.cxracing.com/index.php?route=product/product&path=82_548&product_id=1411
- Post n°89
Re: *the goose*
for some reason these links are not working.
cut new temp/pressure bungs on the lathe last night for the charge piping and plasma cut out the header panel to clear the charge piping.
just picked up the cooler kit today and cx gave me one boot that wasnt correct. called them and they are shipping another out today no charge and no return of the incorrect tube. i even offered to take a picture and send it to him to prove i'm not just trying to get free parts and he still said it wasnt necessary.
Pretty dam good customer service so far! ill get pictures up in a bit of the cooler.
- Post n°90
Re: *the goose*
- Post n°91
Re: *the goose*
Can't see any pictures
- Post n°92
Re: *the goose*
Yeah it didn't work for me either
- Post n°93
Re: *the goose*
- Post n°94
Re: *the goose*
idk why but when i post the link using the link tab it converts it to "[img][/img]" and thats it started doing it about a week ago or so...
in other new i did get the cooler securely mounted and most of the charge piping ran. waiting on a couple more bends to make the discharge pipe at the turbo horn line up right. then off to plumbing the exhaust. THE TURBO IS MOUNTED
- Post n°95
Re: *the goose*
added 3 new pictures to the photobucket album. cooler came out pretty slick and im just a hair off of it being level but im happy either way. just need to wire in the manual fan switch tonight then well be good on all the electrical wirings. until i either get a racepak or buy gauges.
- Post n°96
Re: *the goose*
ok guys im sorry i just looked through photo buckets new site rules and they have disabled 3rd party hosting/embedding of photos into other sites/forums/servers etc if you have the free Photobucket account. Now you have to pay for your account to access this function again.
well im not doing that, so ill try and see if i can find another site to do it with because it says my storage on here is full (gmbodyforum)
- Post n°97
Re: *the goose*
We use servimg as the forums third party host, you cant upload using attach file below a post, I have that disabled since that's not free either. You have to click on host an image button up top then copy and past that into your post, hope this helps!
- Post n°98
Re: *the goose*
GM B-Body Forum wrote:We use servimg as the forums third party host, you cant upload using attach file below a post, I have that disabled since that's not free either. You have to click on host an image button up top then copy and past that into your post, hope this helps!
i'll look at getting that then honeslty!
- Post n°99
Re: *the goose*
did get the manual fan switch wired in. going to put it on a 3 way switch later on so it functions automaticly and manually.
was fighting the tig welder for the past few nights found we had a torn hose on the argon line. got that fixed and were back in business. did order a new larger defused lens and cups to help as well. those should be here tomorrow. ill try and get pictures up by the weekend.
trying really hard to get this thing driving by Aug 4 (my daughters birthday)
- Post n°100
Re: *the goose*
Made some progress this weekend so far. Got the turbo to inter cooler pipe fabbed. Had to redo the intake pipe to the throttle.body due to clearance issues with the exhaust piping. Now it runs over top the radiator outlet on the driver side. Honestly looks way cleaner. And also was able to get most of the cross pipe on the exhaust done. Can say thank you enough for my brothers help with this project!!!!!!!!
