changing the oil before hand and cutting the oil filter apart. because i know this engine didnt have a physical engine knock when i put it in the car. may just be caused the solid motor mounts.
*the goose*
Fierro51- Sophomore Member (Tier 4)
- Post n°151
Re: *the goose*
got the car back have a engine knock issue on the laptop. possibly from bad fuel. so i brought it back home and dumped the fuel tank out putting fresh 91 octane in it and going to put it on a good friends dyno and have the tuner come read it and see.
- Post n°152
Re: *the goose*
well little update,
put the car back on the dyno still have a knock issue. i believe it not a physical engine knock. so as of now haven't gotten the car back to Laramie to get the tune figured out. did get the the knock sensors replaced. also going to install more braces on the turbo mount to help secure it to the frame as its vibrating excessively. so once that is all done hopefully all the cosmic repairs can start on this car.
i am currently in process of buying a full on drag car so this car will not be going under the knife for a back half kit. now i will truly be able enjoy driving it and making it look just as nice an clean as it sounds.
- Post n°153
Re: *the goose*
[img]
[/img] changing some other things up also
- Post n°154
Re: *the goose*
[img]
[/img]
92mm and a holley midrise
- Post n°155
Re: *the goose*
been told that stock lq4 truck injector wont work on this intake. they protrude the same depth as the holley "low impedance" injectors do. These spacers should work just fine.
maybe this weekend ill get the intake swapped weather permitting
- Post n°156
Re: *the goose*
eventually im going to have the lid and the valve covers power coated in the same color then changing the charge piping to black wrinkle coated tubes with red boots
- Post n°157
Re: *the goose*
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
well after a week of issues putting the intake on. turns out that it is not designed for the 4.8-5.3 truck accessories and we had to come up with a "never been done before" fix since im not spending $600+ on ls1 water pump/pulleys alternator and power steering.
[img]
[img]
[img]
- Post n°158
Re: *the goose*
[img]
[/img]
[img]
[/img]
initally the throttle body hit the ilder pulley. now with 1" spacers in place i have plenty of the pulley but i had to order a wedge throttle body spacer to bring the angle up to clear the exhaust cross over
[img]
- Post n°159
Re: *the goose*
[img]
[/img]
before spacers
[img]
[/img]
after spacers
before spacers
[img]
after spacers
- Post n°160
Re: *the goose*
[img]
[/img]
[img]
[/img]
fits much better with the spacer in place for the throttle body
[img]
- Post n°161
Re: *the goose*
[img]
[/img]
[img]
[/img]
took advantage of my extended weekend and thanksgiving to get the car finished up. Was able to get the bov installed and fab up a catch can out of some old 3.5" charge piping so now the car is honestly done with modifications. Once its tuned i will be able to just fix little odds and ends things. The intake/charge piping and fuel system hard parts changing should be all finished "knock on wood"
This week sometime i'm taking it to get the tune finished so well see how it goes
Hope everyone had a great Thanksgiving!!
[img]
- Post n°162
Re: *the goose*
[img]
[/img]
so we took the OH for a drive Saturday morning hooked to the laptop and it had no "Knock Retard" at all. FINALLY!!! Called the guy tuning it and he said he cant make it to town this week which is fine because im going to PRI in Indy on Wed. so me an my little girl took a road trip and got OH dropped off. Hopefully I will be getting a text message with some 3 digit hp/tq numbers this week!
- Post n°163
Re: *the goose*
Before taking the car to Laramie i did score some 9007 Leds from my cousin so i ordered some lenses and put them in as well heres the before and after
i'll probably make a whole new post about this later.
factory halogen:
[img]
[/img]
Single 9007 Led with non diffused housing:
[img]
[/img]
factory halogen:
[img]
[img]
- Post n°164
Re: *the goose*
Really like these led's because they have a high/low function on the low beam light that actually works with the cars factory wiring so NO splicing of any kind.
low beam comparison:
[img]
[/img]
Both Low Beams:
[img]
[/img]
Vision X Replacement lenses:
Like i said these are a non diffused lens so they will put out more use able light at a father distance than factory lens will
[img]
[/img]
[img]
Both Low Beams:
[img]
[img]
- Post n°165
Re: *the goose*
High beam fuction: You cant see it very well but the back wall above the selves is lit up enough you can read the box,pain can and other tags easily
[img]
[/img]
[img]
[/img]
[img]
[img]
- Post n°166
Re: *the goose*
little update
got a call Sunday that the car blew out an exhaust manifold gasket. and was literally burning through plug wires
went to Laramie and helped swap gaskets and plug wires. Gave them some fuel line wrap and we wrapped all the wires were they were hitting the header wrap. Asked how it was going other than that and they said well.. its hitting 20+ psi of boost and the waste gate isn't opening and the brand new map sensor only reads 105 kpa max (5 psi). So called it quits for the night. They road tested it Monday and its drive able, just need to get the new map and figure out the gate and we can finish the WOT runs. But in-climate weather was coming in as of Wed night so went an picked up the car Monday evening.
Drove it to work Tues and Wed. Car has a hot restart issue but that's an easy fix. Called the Map sensor company they are sending me a replacement map sensor. Once that gets in well put it on good friend of ours local dyno here in town and my tuner is going to come down and get it all finished so i don't have to take it back over there.
Ordered a new cast aluminum transmission pan, then a locking flexible dipstick for the transmission from lokar to fix the transmission leaks. also ordered coil bracket relocation kits and extension harness. going to be putting the coils on the engine block
Will say this SUM-BEETCH HAULS the F-N MAIL when it hits boost.
it goes from 5 psi to 25psi+ in about 2 seconds if your are not careful with the throttle pedal! makes about 7psi at 3000rpm. but now its getting the 4:10 swap sooner than later. Doesnt really like the stop light to stop light driving, and i dont want to flash the converter
But so far the best part of all i got to suprise my little girl Wed when i picked her up from school in it! Made her day to say the least.
Now with 3" of snow on the ground and no garage to put it in it may not be till next week when i get to work on it again so ill keep everything updated
ALSO HUGE SHOUT OUT TO SWEET SEVENTY9 he got me a good 77 impala tail light, headlight bucket, front corner fender housing, nos front turn signal housings and a set of good door hinges for the car!
Just want to say thank you for what you do, because without you i couldn't get this thing anywhere near my goal!!
- Post n°167
Re: *the goose*
well ordered these up today
[img]
[/img]
[img]
[/img]
[img]
[/img]
iq3 street dash with gps module and extra 0-150psi sensor
[img]
[img]
[img]
- Post n°168
Re: *the goose*
well blew up the "stock" th350 and had to sell the racepak to get a th400 built. should be done today
did get some led front marker lights/turn singals in the car. really recommend them. still trying to figure out why my led turn signal relay isnt working properly.
[img]
[/img]
[img]
[/img]
note to anyone putting led in tail lights buy red led bulbs otherwise they look like this and the lights look orange and no red
[img]
[/img]
[img]
[/img]
also my mark Williams C-clip eliminators for stock axles showed up. going to be swapping the 4:10 axle for now until i put a set of 3.73s in the other housing with good axles.
[img]
thought this might make some people smile. my little get reaped the benefits of me getting a new 1/2 impact for for, she got her own snap-on hairdryer
[img]
[img]
[img]
[img]
[img]
- Post n°169
Re: *the goose*
[img]
[/img]
i have had these sitting around for about a month waiting to install them along with some fabricated non coil valve covers.
so hopefully the weather clears up and everything can get done sooner than later.
- Post n°170
Re: *the goose*
[img]
[/img]
swapped the 4.10 8.5" this weekend. found out it was out of a pontiac and is a factory c-clip eliminator axle housing. housing length itself is 56 1/2" and
with two 30-3/8" axles it measures 62" axle flange to axle flange with mark williams eliminators. old diff measured 61 1/2" flange to flange
going to run them until i have an issue before spending money on aftermarket BOP axles and BOP style eliminators
will be doing a disk brake conversion on the rear next as the left side brake shoes were taken apart by the previous owner for racing purposes.
[img]
[/img]
[img]
[/img]
factory BOP non c-clip axle housing
[img]
[img]
- Post n°171
Re: *the goose*
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
[img]
[/img]
BOP cover moser axles and s 10 brake conversion
[img]
[img]
[img]
[img]
[img]
- Post n°172
Re: *the goose*
BOOM
- Post n°173
Re: *the goose*
with a 1/4" spacer installed
wheels are a 15x10 6.5" offset if they dont work ill sell them for some 5.5s
- Post n°174
Re: *the goose*
will test fit them tonight with a set of 28x10.50 et streets
- Post n°175
Re: *the goose*
new 3.5" tube drive shaft
and got the th400 in last night
