    steering coulmn question
    Fierro51
    Fierro51
    Sophomore Member (Tier 4)
    steering coulmn question Empty steering coulmn question
    Post  Fierro51 Thu Jan 28, 2016 9:55 am
    hello i have a 77 2 door coupe and I need to replace my steering column and I cant seem to find another cruise control column around me. i have found several non cruise columns and I am wondering if you can take a non cruise control column and make it cruise control, all the parts are mechanically the same it just takes an electric stalk/lever correct?
    any help would be appreciated
    steering coulmn question Empty Re: steering coulmn question
    Post  GM B-Body Forum Thu Jan 28, 2016 11:27 am
    Yes you are correct, just find you a 77 to 83 cruise control/turn signal lever. And GM used them on other models too like the corvette also, so they arent hard to find.
    Fierro51
    Fierro51
    Post  Fierro51 Thu Jan 28, 2016 11:35 am
    GM B-Body Forum wrote:Yes you are correct, just find you a 77 to 83 cruise control/turn signal lever. And GM used them on other models too like the corvette also, so they arent hard to find.
    didn't the none cruise columns  have just a thread on turn signal lever and the cruise levers were bolt in?
      Current date/time is Fri Mar 31, 2023 6:23 pm
