Rear Sway Bar Installation
oldsbuickhybrid- Active Member (Tier 2)
I was thinking of getting a rear sway bar from the local junkyard. The owner was going to sell the sway bar, along with all mounting hardware. After speaking with him today though, he said he was not going to be able to get the parts, so now, I am looking online since b bodies are pretty hard to find down here. Upon looking for sway bars online, I noticed that there is no hardware provided. How are rear sway bars installed? What additional parts and hardware are required? Bushings? Endlinks?
Re: Rear Sway Bar Installation
It runs under the rearend and connects to the lower control arms on the bottom that hold the rearend(axle) in place along with uppers.
The GM rear lower control arm kits from GMPD have all the necessary hardware to mount a sway bar.
They don't just bolt on, there's plates that the bolts go through that you'll need to use.
Edit - Here's the front bar you'll want - http://www.ebay.com/itm/270870346977
It's the Z28/WS6 F-body front bar. Most aftermarket front bars for B and F bodies are based on it.
Myloth wrote:It runs under the rearend and connects to the lower control arms on the bottom that hold the rearend(axle) in place along with uppers.
Ah I see. I thought I was going to have to drill holes to the body
Sweet Seventy9 wrote:The GM rear lower control arm kits from GMPD have all the necessary hardware to mount a sway bar.
This is some great info! I had no idea that the f body sway bar fit b bodies. Thanks for the link, Also, I had not noticed that the hardware was provided in the arm kit.
I found a used Impala SS rear sway bar on ebay, but it came with no hardware. Now that I know the hardware is in the arm kit, I will get it. and apply a coat of paint to it.
For the front bar, I will definitely get the f body bar. At 1 1/4, this seems to be a great bar for the money. I may have to wait a couple of weeks though to save up some money lol
I just saw your Photobucket pics. I absolutely love your car's setup. That front sway bar looks huge. After seeing it, I will definitely have to get it ASAP. Thanks for sharing.
TMCKERROW- Active Member (Tier 2)
88 wagon rear sway bar
Anyone have any idea how to mount a rear sway bar to an 88 wagon? The width is 4" wider than the sedan or coupe, so I'm kind of stuck. I think I saw somewhere where a person was able to fit a 77 sway bar on the rear, but anyone else know of this?
No the 77's are too narrow(unless you mean another wagon) your best bet is this from Addco. Made specifically for Wagons.
https://www.summitracing.com/parts/aco-881?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-addco&gclid=Cj0KEQjw1K2_BRC0s6jtgJzB-aMBEiQA-WzDMU6lL2FfY1_AEpsVBv7QRpbAvpXeHtZBzE6j-JIHlJoaAuCE8P8HAQ
- Post n°9
Sway bar
I'm looking for a way to get a rear sway bar on an 88 wagon. And, Id like to try and keep it GM. I plan on using an Fcar WS6 front sway bar though. Any 77-96 rear sway bar is going to be too narrow as far as Ive found. Except, maybe, a truck rear end....thoughts?
- Post n°10
The only place you'll find a GM sway bar is from another wagon, And GM did not use very many on wagons and when
they did they too small anyway. A that 881 Addco(That one is made for wagons) bar will tighten that wagon rearend up like you won't believe but
there is nothing from the factory that will do half as good they just did not make them.
- Post n°11
rear sway bar
Are you sure you gave me the right link? That one says its for the front end.
- Post n°12
Bringing back this thread from the dead, but my project has resumed, and I am finally considering going through with the sway bars. Above I saw the recommendation for the front sway bar. Which vehicles could I get a rear sway bar from? Thank you
- Post n°13
sway bar?
I have one of the F-Body bars on order.
Their back logged until they can get more.
That's for the FRONT bar.
- Post n°14
As far as the rear bar you are better off getting an aftermarket piece like this.
http://www.streettrendsinc.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=BBODY&Product_Code=75515&Category_Code=BOX_SUSPENSION
The factory rears aren't very good compared to these. They are thinner and barely adequate my frontend is super
tight with the 2nd gen F body front bar but the back is like the Hotchkis bar in appearance but smaller and it feels
weak for it.
weak for it.
- Post n°15
Bar
The rear bar I have was off a 1992 Buick Roadmaster and its solid.
It came with the 8.5 rearend I purchased to rebuild and install.
It had 3.08 posi. gears. I changed it to 3.73 and bought the upper and newer Lower control arms w/accessories for the bar.
The housing has installed 2 poly bushing in the ears.
Having it installed made all the difference on the rear stiffness of the suspension.
As soon as the new front F-Body bar comes in it will be installed.
Its not going to be a corner cutter, but just feel more controlled when driving.
- Post n°16
I have a solid factory bar in the rear as well. I think it's 7/8 or 1" but I can to me front has way less
roll than the back . I also have poly everything and Southside Upper and Lower links to my rear-end.
Ever since I installed the 1.25 front I can turn on the dime but it always feels the rear is dragging a bit behind.
- Post n°17
My car coming from the stock condition is a much better ride. And will be better when the F-Body bar is in.
I'm not 25 anymore that I have to broad slide around corners. Its just a cruiser!
And the wear on the parts are not cheap anymore.
- Post n°18
I hear that and I don't mean to say I am looking a NASCAR style ride on the rear. I just find the rear feels loose
in comparison to the front. My front end has a really nice ride, stiff in corners and takes a 5mph speed bump at 10
with aplomb. Maybe I need to change my rear shocks . My fronts are Gabriel HDs the rear are supposedly 9C1
equivalent from Monroe. But my experience with other Monroes has told me Monroe is mediocre maybe I'll try
different shocks before the rear bar swap. (lot less $$ anyway)
