At the moment, I am swapping my 307 for a 455ci engine from a 1976 Buick Electra which I have slightly modified. Along with the engine, I am also swapping in a th400 from the same Electra and an 8.5 rear from a 1995 Buick Roadmaster.
After that, I am going to work on my suspension. I am going to replace my oem springs with lowering springs from a 1990's Impala, install kyb exel g shocks, sway bars from an early 90's Buick Roadmaster, Roadmaster frame brace, and possibly poly bushings for the sway bars.
Once all that is done, my funds are pretty much done for, and I have to start saving up for a much needed paint job
Also, I have a quick question. Does anyone know the steering box ratio my OEM Delta has? Is it an adequate performance ratio?
I will post pics of my project next week.
