    frame repair
    mattlarthur
    frame repair Empty frame repair
    Post  mattlarthur Mon Oct 12, 2015 11:50 am
    i have found some rust holes on the rear frame rails (under trunk) on my 77 Caprice 2 dr. are there replacement parts available or is this a "weld in patch panels" project? i know El Caminos have this problems also. thanks
    Marx3
    Marx3
    frame repair Empty Re: frame repair
    Post  Marx3 Fri Nov 06, 2015 11:08 am
    I recently did extensive rust repair on the frame of an 86 caprice.
    I cut patches to exact fit, from a 3 mm thick steel sheet.
    If you are a reasonably experienced welder I would advise you to just to the "patchwork".
    frame repair 22F5AD02-C095-48CF-8C1A-6FE842D79357_zpsij2i7qfs
    frame repair 7034202B-71E5-4B4D-8C51-46A65D03AA84_zps0yqemtio
    frame repair 3C1358ED-F6BF-40CF-8D95-31C2815E9B7B_zps2iw30gjg
    frame repair BCA86D4B-06BC-4558-B307-53F7C9A7CD6D_zpsyg3haqyn
    Post  solo79 Sat Nov 07, 2015 6:07 pm
    Nice work on the frame repair!! Top notch!
      Current date/time is Tue Mar 21, 2023 10:58 am
