    Aftermarket Shifter
    Aftermarket Shifter  Empty Aftermarket Shifter
    Post  Myloth Sat Aug 29, 2015 6:56 pm
    I just installed my Hurst shifter and the last time I put one of these in a friend did the linkage and that was umpteenth
    years ago. So my knowledge of the actual detent cable mount positioning is non-existent at this point. Here are
    pictures I took today can anyone tell me what I am missing this Quarter stick pulls into Park and pushes into drive with
    the alignment shown at the pan in the picture how is that possible when Park is clockwise and 1st is counterclockwise?
    And from numerous searches this orientation seems the most common?
    I just called Hurst and I am not crazy the shifter is a rear exit and that orientation doesn't work I have to move
    everything as he put it from 6o'clock to 12 o'clock ? I assume he mean everything has to be above the pan lip?
    Aftermarket Shifter  Th_P8290003
    Aftermarket Shifter  Th_P8290004
    Aftermarket Shifter  Th_P8290007
    Aftermarket Shifter  Th_P8290005
    Aftermarket Shifter  Empty Re: Aftermarket Shifter
    Post  Sweet Seventy9 Sun Aug 30, 2015 10:19 am
    Are you sure the shifter is mounted correctly? I could be wrong but it looks like the it's mounted backwards. Shouldn't the park/reverse lock-out handle be in front of the shaft?
    Post  Myloth Sun Aug 30, 2015 11:57 am
    OMFG what a ninny I feel like I knew something was backwards here I guess it was just me!
    Post  Sweet Seventy9 Sun Aug 30, 2015 12:33 pm
    What'cha been smoking? Laughing
    Or me?!? The lever I referred to is actually the trigger, lol.
    Post  Myloth Sun Aug 30, 2015 1:52 pm
    I know what you meant and you were 100 percent lol.
    Here is what it should have looked like (and does now) and it works great without any adjustment I just took it for
    quick spin.
    Aftermarket Shifter  Th_P8300008
    Aftermarket Shifter  Th_P8300009
    I should have realized with the other way it didn't just pull through lol. Now I'll have to pony up 45 for the Hurst cover or
    make my own. There was one I seen on ebay that had Hurst and Chevy on it!
    The only thing I didn't have that I had to cob was the cable didn't come up clips and Hurst clips are 22 dollars a piece!
    So I used 5/8 E clips (A whole .28 in hardware store) and hope the will hold for a while. In case anyone is wondering
    the Quarter Stick I have came with the safety/rev switch I just have to hook it up now :} :}
    Post  Myloth Sun Aug 30, 2015 3:35 pm
    Here it is installed thanks Sweet! And just ignore the last 10 sec lol sloppy editing.
    That Reverse lockout obviously will take some getting used to!
    Post  Sweet Seventy9 Sun Aug 30, 2015 8:15 pm
    Excellent! you got it worked out!
    If you're unfamiliar with a 1/4 stick, here's how to use it - put the trans in 1st, nail the go pedal, at the proper RPM bang it straight into 2nd without the trigger, when ready for 3rd grab a handful of the trigger and bang 3rd.
    The reverse lockout mech is a pita to use every time you park, but worth it.
      Current date/time is Tue Mar 21, 2023 9:42 am
