+4
8 posters
    Quarters and rockers
    Quarters and rockers  Empty Quarters and rockers
    Post  Myloth Wed May 06, 2015 11:53 am
    http://www.noramstore.com/category_s/236.htm
    Anyone ever see this place or buy from them?
    On the same line how different are the rear quarters 4dr and 2dr quarter panels? Could one be used as a good
    template for the other? Anyone ever try that as my lower rear quarters are toast?
    Quarters and rockers  Empty Re: Quarters and rockers
    Post  GM B-Body Forum Thu May 07, 2015 10:41 am
    Im thinking the only difference between the two and four door quarter panels is just the back glass, so im sure some mods would have to be done, im just surprised to see a company offer anything like that! I see the rockers, and lower door skins alot but never a quarter panel, were getting one step closer to getting parts for our cars!!
    Post  Myloth Thu May 07, 2015 2:07 pm
    Yes that was a nice surprise! My quarters rotted just on the bottom but there are few spots up top could
    be worse if the paint was off. Glad it is available, when I look at the 2dr and 4dr other then up top
    they look pretty close.
    Post  Sweet Seventy9 Fri May 08, 2015 4:15 pm
    Nice find, Bro!
    From roughly the center of the wheel opening to the rear they're identical.  The top will be slightly different near the window but if you cut from the top or side body line you'll be fine.  If you get one (or both sides) you'll see where you need to cut.
    Quarters and rockers  7256_310
    Quarters and rockers  Image012
    Post  solo79 Fri May 08, 2015 6:41 pm
    Yes, very nice find indeed. I have a couple of 3"+ diameter rust holes behind my lower trim on both sides of my rear quarters. I could simply cut out a perfect patch panel instead of making my own at that price!
    Post  Myloth Sat May 09, 2015 6:34 pm
    Thanks for the info yeah I am going to go for a pair both sides are just a lot of fab at the bottom. And they
    would seem to be the perfect patch panels trim what you don't need.
    Xtreme Thunder
    Xtreme Thunder
    Post  Xtreme Thunder Tue May 19, 2015 6:31 pm
    Great find!
    Would love to see a full quarter panel for coupe though, from rear tails to the door, i.e. Full wheel opening included.
    Slowing making headway on some good body panel reproduction part offerings!
    mylilcaddy
    mylilcaddy
    Post  mylilcaddy Tue May 19, 2015 6:48 pm
    Great news on the quarter panels. Now I hope they start breaking them into sections. I also have the large hole behind the rear wheel under the trim, driver's side only. Will get out to the remote antique to vintage bone yard here in W.KY and look for our cars and drop a line if successful.
    jaked1985
    Post  jaked1985 Tue Aug 09, 2016 11:56 am
    would the lower door patch panels work to patch the lower section of the rear quarter behind the tires?
    Post  Kit1078 Wed Aug 10, 2016 8:34 am
    my only concern is that the listing says "77-90 Quarter Panel"
    Post  Myloth Fri Aug 19, 2016 12:03 pm
    Even if it's not a perfect fit it would make a good panel even if you had to alter it slightly especially
    if you have rot like I do in the lower quarters. Hopefully soon I can get a pair of the quarters and skins.
      Current date/time is Fri Mar 31, 2023 5:47 pm
