    Top outside door trim removal.
    79treemaster
    Top outside door trim removal. Empty Top outside door trim removal.
    Post  79treemaster Mon Sep 02, 2013 7:16 pm
    Wanting to remove the trim on the top of of the door. Is it bolted down or does it have clips that hold it on?
    Top outside door trim removal. Empty Re: Top outside door trim removal.
    Post  GM B-Body Forum Mon Sep 02, 2013 7:58 pm
    Im assuming your talking about what i have circled in the pic below, if so to answer your question, neither, there are no bolts or clips, it just kinda slides on, really simple, but you have to take the piece with the 4 screws off first thats going down the channel run.
    Top outside door trim removal. Trim_p10
    79treemaster
    Post  79treemaster Mon Sep 02, 2013 10:51 pm
    Sorry I should have said at the window sweeps.
    Post  GM B-Body Forum Tue Sep 03, 2013 10:28 am
    Ohh ok, i think i got what you mean now, the trim piece that sits right on top of the window sweep is actually part of the window sweep and cant be removed, ofcourse you can remove the window sweep, but youll have to take the door panel off first, and i believe there are 5 screws holding it down. Hopefully i got it right this time lol
      Current date/time is Wed Nov 29, 2023 3:01 am
