+3
78i6belair
paulboncz
7 posters
    Seat Belt Buzzer
    paulboncz
    Seat Belt Buzzer Empty Seat Belt Buzzer
    Post  paulboncz Tue Feb 17, 2015 4:24 pm
    1979 Impala 4Dr. 350 V8. See picture at http://www.pab3790.wix.com/mysite. I cut these wires 2 years ago and marked which goes to which but the marks didn't hold up. I want to reconnect. Does it matter how I do it? Is there a polarity? Thanks.
    78i6belair
    78i6belair
    Seat Belt Buzzer Empty Re: Seat Belt Buzzer
    Post  78i6belair Sun Nov 08, 2015 9:54 am
    I do believe that polarity dosen't matter. I'm almost positive the seatbelt warning system is just a set of open contact points that the seatbelt closes when you insert it into the latch assembly turing off the light/buzzer before it times out.
    Post  Myloth Sun Nov 08, 2015 10:55 am
    Sadist
    Post  solo79 Tue Nov 10, 2015 8:30 pm
    Myloth wrote:Sadist
    What was this comment for?
    Post  Myloth Tue Nov 10, 2015 9:07 pm
    A seat belt buzzer??
    Lol my fiancee has a CR-V that if you take the belt if it rings every 20 sec UGH the
    humanity. The first thing I did to mine was disconnect it as I live on a private road
    so when I go get my mail etc I don't need to put my seatbelt on, I hate seat belt buzzers
    other than taking your car to a show if it was a resto why would want that thing hooked up
    unless you are into torture?
    Post  solo79 Wed Nov 11, 2015 6:40 pm
    Myloth wrote:A seat belt buzzer??
    Ahh, I get it now. The buzzer would never bother me because I always wear my seat belt. However, it didn't work in my first Caprice and it doesn't work in the one I have now either.lol That's probably not something I would fool with hooking back up or repairing because I don't need a reminder, but if you are going all out to make sure everything works, well, then every little detail counts. In my Pontiacs, it's nothing more than a light on the dash with no sound.
    Post  Myloth Wed Nov 11, 2015 8:19 pm
    The buzzer was working in mine too well.....
    Marx3
    Marx3
    Post  Marx3 Wed Nov 25, 2015 3:55 am
    My 79 dont make the buzzing sound, it only light the lamp in the dash.
    Did all all caprices have the buzzer?
    I would really like to have it, since the car is so unmolested.
    78i6belair
    78i6belair
    Post  78i6belair Wed Nov 25, 2015 7:09 am
    Marx3 wrote:My 79 dont make the buzzing sound, it only light the lamp in the dash.
    Hi there. Our B cars have two warning buzzers, one for the door ajar while the key is in the ignition tumbler and the other is for the seatbelt warning system. Both buzzers are located near the fuse box. The one for the door ajar/key is a small grey box that just plugs right in the fuse box.
    Marx3
    Marx3
    Post  Marx3 Wed Nov 25, 2015 7:27 am
    Aha, so mine should have the buzzer already?
    I gotta look into this.
    Gooched78Caprice
    Gooched78Caprice
    Post  Gooched78Caprice Thu Nov 26, 2015 12:47 pm
    After seeing this and never really noticing any buzzing I  checked and noticed I have the keys in ignition buzzer and seat belt light in dash. Never heard any seat belt buzzer before. Was always hoping to get everything working correctly and thought all I had left was the "digital" clock to have her 100%, this is one I'll also be fine without.
    Dumb question but with the different dash displays for these cars. I was curious if the cars that have the seatbelt buzzer also have a dash light? I have the more circular dash console showing seat belt light but never heard buzzing due to seat belt.
    Xtreme Thunder
    Xtreme Thunder
    Post  Xtreme Thunder Sat Nov 28, 2015 2:59 pm
    Not sure about the '77-'79 (I'd assume pretty similar circuit operation), but in my '87 Electrical Diagrams, Service Manual Supplement it lists two options, Buzzer or Chime, both work the same with following System Check:
    1. Seatbelt Warning. Sit in driver's seat with LH door closed. Turn the Ignition Switch to "Run", and do not buckle the seatbelt.
    - A slow chime alarm sounds.
    - "Fasten Belts" indicator lights in Instrument Panel.
    - Chime stops and indicator goes out after 4-8 seconds.
    2. Key Warning. With Ignition Switch in "Accy", "Lock", or "Off" but the key is still in ignition, open the LH front door.
    - Fast chime alarm sounds (faster than seatbelt chime).
    3. Remove key from Ignition Switch.
    - Alarm stops
    4. Lights On Warning. With the key removed from the ignition, turn the Light Switch to "Park" or "Head".
    - Fast pulsed chime alarm sounds (faster than key chime).
    5. Turn lights "Off".
    - Chime stops
    Note, difference between the two is that the Buzzer (Audio Alarm Module) and the Chime (Multi-Function Chime Module) is that the former does not use the input for the "Lights On" reminder.
    FYI, my '87 Coupe has the Chime option.
      Current date/time is Thu Mar 30, 2023 4:18 pm
