My old Riviera had 12in drums and the 15" wheels were a special size to fit the 12 Aluminum drums
are the B Body 15" wheels like that or as most Wagons came with 15s no? and didnt most wagons have 12"
brakes?
yo sweet i was looking to swap the fronts to 5x5 bolt pattern to match the rear axle and might as well upgrade from 11" -> 12" rotors the was this car for parts its a 92 olds98 sedan bubble body.Sweet Seventy9 wrote:
If you go used, look for these cars for donor parts:
Buick, Pontiac, or Chevy full size 1978-1992
Caddy Seville and Deville 1978-1992 execpt for limos
Olds Delta 88 coupe and Sedan 1978-1992
Buick Riveria 1977-1979
If compatible do i grab the spindle/rotor wHub/caliper & brackets and thats all i was gonna replace hoses and rebuild calipers
i seen that but i got 205/70r15 tires and have about 4" off the ground if i lower it more ima get stuck on speed bumps LOLSweet Seventy9 wrote:HeavyChevy77 wrote:
Yup, swap over the spindles and everything mounted to them. The 12" front brakes use what are referred to as the "Tall" spindles. There's a write-up on here someplace with fairly detailed instructions, even part numbers. If you want to go crazy, Belltech makes dropped spindles.![]()
Sweet Seventy9 wrote:I just checked the site and cant find it either.
Here's the info in a nut shell: swap out these parts.![]()
General Motors
front spindle, left 1ea, pn. 14012589
front spindle, right, 1 ea, pn. 14012590
1LE 12-inch rotors, 2 ea, pn. 18016035 - (for 5x4.75 bolt pattern)
Dustshield, left, 1 ea, pn. 344023
Dustshield, right, 1 ea, pn. 344024
Dustcaps, 2 ea, pn. 1400344
Washers, 2 ea, pn. 457707
Nuts, 2 ea, pn. 378137
Calipar bolts, 4 ea, pn. 5463495
Caliper, left, 1 ea, pn. 18015427
Caliper, right, 1 ea, pn. 18015427
Wheel bearings and seals.
