Sasmo
    Ford 9" rear end swap out-refit - axle width?
    Sasmo
    Sasmo
    Ford 9" rear end swap out-refit - axle width? Empty Ford 9" rear end swap out-refit - axle width?
    Post  Sasmo Sun Feb 08, 2015 2:49 am
    Anyone know the width of our 79 Caprice's rear axle - Axle flange to axle flange?
    I am considering putting in a new custom fit Ford 9" rear end, 3.50:1 ratio.  I may also go used and put in the work to shorten one if I can't find one close to the same Caprice width...
    Anyone out there with experience in this regard?
    Ford 9" rear end swap out-refit - axle width? Empty Re: Ford 9" rear end swap out-refit - axle width?
    Post  HeavyChevy77 Sun Feb 08, 2015 12:02 pm
    Sasmo wrote:Anyone know the width of our 79 Caprice's rear axle - Axle flange to axle flange?
    Use a impala ss rear from 94-96
    8.5" rear, 3.08 gears , rear disk brakes and posi
    Grab from the driveshaft and back
    Also will need new master and combination valve to make rear disk work right
    Sasmo
    Sasmo
    Post  Sasmo Sun Feb 08, 2015 3:40 pm
    So no answer on the axle width question then? I have been searching locally for the Impala SS rear end with no luck yet.
    Post  HeavyChevy77 Sun Feb 08, 2015 3:50 pm
    Impala rear is 59 backing plate to backing plate and that rear is just a lil bigger than the caprice
    Grab a measuring tape and measure ur rear from back of drum to drum
    Also b body gm rears fit caprice 9c1, delta 88, etc
    Post  Sweet Seventy9 Sun Feb 08, 2015 3:57 pm
    For direct bolt-in rear ends, here's what RPO codes to look for in the 91-96s:
    Ratio     RPO Code.                   Application
    2.56          GM8                    Std. Roadmaster LT1
    2.73          GU2                     Std. Caprice L99 (exc. 9C1)
    2.93          GW9/GU3            Std. Caprice LT1 (exc. 9C1), Opt. Roadmaster LT1
    3.08          GU4                    Std. Caprice 9C1/LT1 (Police), Std. Impala SS
    3.23          GU5                     Opt. Caprice L99, Std. Caprice 9C1/L99 (Police)
    3.42          GU6                     Std. 91-93 Caprice 9C1/L05, Std. 94+ Fleetwood w/V4P
    3.73          GT4                     Std. 91-92 Fleetwood Brougham w/V4P
    Post  Sweet Seventy9 Sun Feb 08, 2015 4:18 pm
    This might help too.
    Chevy:
    2GF / 7.625" / 2.93 (RPO GW9) ratio / 9.5" drum / 1598mm width
    (soft-mount bushings)
    2GG / 7.625" / 2.93 (GW9)/ 9.5" / 1598mm
    (firm-mount bushings)
    The remaining axles are all 8.5"
    4ZB / 2.93 (GW9)/ 11" / 1566mm (taxi)
    2LQ / 2.93 (GW9)/ 11" / 1598mm Limited Slip
    2LU / 3.23 (GU5)/ 9.5" / 1598mm w/LS
    2LT / 3.23 (GU5)/ 11" / 1566mm
    2LS / same as 2LT w/LS
    2GU / 3.23 (GU5)/ 11" / 1566mm w/LS (taxi)
    2LY / 3.23 (GU5)/ disc / 1566mm (police)
    2LZ / same as 2LY w/LS
    2LW / 3.08 (GU4)/ disc / 1566mm (police)
    2LX / same as 2LW w/LS
    2LL / 3.08 (GU4)/ disc / 1598mm w/LS (Impala SS only)
    Buick:
    2GC / 2.56 (GM8)/ 11" / 1566mm
    2GQ / same as 2GC w/LS
    2NS / 2.93 (GW9)/ 11" / 1566mm w/LS
    ALL WAGON AXLES:
    2YN / 2.56 (GM8)/ 11" / 1642.5mm
    2YF / 2.93 (GW9)/ 11" / 1642.5mm
    2YG / same as 2YF w/LS
    Sasmo
    Sasmo
    Post  Sasmo Sun Feb 08, 2015 11:43 pm
    Thank you.  My ride is in storage for the next couple of months for the winter, so I can't find out the width my self right now. The list of rear ends are a helpful, did a search on them and the 91 Caprice police rear ends are rich in supply, maybe retired high mileage cop cars. My car guy that would be helping me with the rear end upgrade is going to try and find a pre-fabbed 9" Ford rear end for a B-body, if not, he would get a bare rear end and mount the perch and brackets himself(we'd probably be doing some suspension work to).  I just have to make the decision, my hesitation on the matter is only from what I read about, that the used GM ring gear could fail far easier than a new "bullet proof" ford. I have a week to decide before we set out to start buying parts.
    Post  HeavyChevy77 Mon Feb 09, 2015 9:52 am
    The 9c1 are a good choice 8.5" axle some w/posi
    Grab the control arms and its plug and play
    The ford rear is good but the 8.5" is far from weak
    Look toward the bottom under the pic of the camaro doing a wheelie
    http://www.superchevy.com/how-to/48518-posi-10-bolt-upgrade-install/
    Post  Sweet Seventy9 Mon Feb 09, 2015 10:23 am
    You can still buy new 9C1 lower control arms at GM Parts Direct for something like $50 + shipping.  It comes as a complete kit with both LCAs with bushings installed and all the mounting hardware for the arms AND a sway bar.
    If you're concerned about breaking a rear end it might be a better idea to use aftermarket control arms though.  There's lots of them out there.
    http://www.gmpartsdirect.com
    Put - 10289786 in the search box.
    $45.70 for the kit.
    Last edited by Sweet Seventy9 on Mon Feb 09, 2015 10:35 am; edited 1 time in total
    Post  HeavyChevy77 Mon Feb 09, 2015 10:27 am
    Ooh ooh tell him bout the Southside machine shop arms less than $300 for all the arms and the hardware
    Post  Sweet Seventy9 Mon Feb 09, 2015 10:32 am
    HeavyChevy77 wrote:Ooh ooh tell him bout the Southside machine shop arms less than $300 for all the arms and the hardware
    That's a pretty good deal.
    Post  Myloth Mon Feb 09, 2015 11:39 am
    I believe the stock 7.5s are 57ish? and the 8.5 are closer to 60(59?) from what I measured.
    Can't beat a ford 9" though for durability and gear changes though. Whatever you do don't think Oem 8.8 Ford (friend
    just toasted one with a straight 6cyl 4 wheeling with just under 100k.)
    Post  GM B-Body Forum Mon Feb 09, 2015 12:18 pm
    As far as GM rear ends, i wouldnt waste time or money in something other than a 8.5 10 bolt or the 8.875 12 bolt, both are solid rears, ofcourse the ford 9 is pretty much the holy grail of rear ends, but there are many folks running 8's and 9's with an 8.5. I just fried my 7.5 rear end earlier last year with a stock 350, and upgraded to an 8.5.
    Fierro51
    Fierro51
    Sophomore Member (Tier 4)
    Post  Fierro51 Wed Feb 03, 2016 6:31 pm
    Did the op ever get the swap done
      Current date/time is Wed Mar 29, 2023 12:44 am
