    Moser Engineering Rear End
    jacob79caprice2dr
    jacob79caprice2dr
    Moser Engineering Rear End  Empty Moser Engineering Rear End
    Post  jacob79caprice2dr Tue Aug 27, 2013 4:47 pm
    If your making serious horsepower, your stock axle is not going to hold up. Moser Engineering has a complete bolt in kit for the 77-96 B bodys. Its a Ford 9in carrier, they dont seem to have Chevy 12 bolts for the B Bodys. They also have what they call "muscle pak" this is a completely assembled ready to bolt it, with brakes included. The link below just takes you to the regular 9 inch rear for you to customize it. http://www.moserengineering.com/complete-rear-end-assemblies/9/9-housing-axle-package-inch-part-number.html
    plepgeat
    Moser Engineering Rear End  Empty NOT A Moser fan
    Post  plepgeat Fri Oct 04, 2019 8:46 pm
    Bought Moser's Ford 9" with disc brakes for my LS-swapped '79 Delta 88.
    The gears were set up wrong, the brake calipers leaked, the rotors were chintzy, and the axles and tubes were juuuuust weird enough to not work well with parts from other vendors. I'd go a different direction if I had it to do over again.
      Current date/time is Wed Nov 29, 2023 3:08 am
