    Wilwood Brakes
    Wilwood Brakes Empty Wilwood Brakes
    Post  GM B-Body Forum Sat Jul 13, 2013 3:58 pm
    This is for the folks who are serious about performance and looks. Id love to have a set of wilwoods all the way around one day. http://www.wilwood.com/BrakeKits/BrakeKitAdvisor.aspx Just select the year, make, model and what size your factory rotors are, you more than likely have 11in rotors if your not sure. I believe the 9c1's and f41's had the 12in rotor, but that means you would have the 5x5 bolt pattern.
      Current date/time is Fri Jun 09, 2023 9:55 am
