    Door Seals
    Door Seals Empty Door Seals
    Post  Myloth Mon Aug 25, 2014 3:15 pm
    I was about to replace my door seals and I noticed that there is no sealant between the seal and the door?
    On my Mopar cars they always used sealant these only use the plastice tabs and that's it?
    Or is it a good idea to seal them with some black rtv ?
    Door Seals Empty Re: Door Seals
    Post  solo79 Mon Aug 25, 2014 7:44 pm
    When I replaced the door seals on my first car 14 years ago, it fit and performed perfectly with no added sealer needed. It also made the doors nice and tight. I don't think you would need any extra sealer to hold them on. I also have 80s Pontiacs and none of them have sealer between the doors and rubber and do not leak.
    Post  Myloth Mon Aug 25, 2014 9:41 pm
    Ok thanks I thought they did. I did seals on few Furys and they used a sealant, good saves some cash then. I can change em out in the morning I already did the trunk and used a light touch of RTV but that is different type of seal altogether.
      Current date/time is Fri Jun 09, 2023 11:32 am
