*For the 77-79's*
Topics | Replies | Author | Views | Last Posts | ||
![]() | 1979 Caprice Seat Belt Chime | 0 | Carcrazed | 8 | ![]() by Carcrazed | |
![]() | Wiring Diagram for 1979 Caprice | 2 | carcrazed79 | 71 | ![]() by slimwud | |
![]() | Headers for 77 2 Door impala | 2 | Feefifofum | 114 | ![]() by Feefifofum | |
![]() | -77 Caprice 2 door frame | 4 | Perg | 489 | ![]() by Boogie1468 | |
![]() | Relocate gas filler cap to left rear quarter panel | 5 | olbaldi | 406 | ![]() by blacknred79 | |
![]() | Electric fans controller keeps blowing fuse | 3 | tero78 | 322 | ![]() by slimwud | |
![]() | Doorseal caprice 77 Classic. | 1 | Bwalfen | 227 | ![]() by slimwud | |
![]() | Mice Damage | 2 | paulboncz | 360 | ![]() by paulboncz | |
![]() | 1979 Impala Oldsmobile Engine Swap | 6 | oldsrocket1973 | 321 | ![]() by Guy Newport | |
![]() | 8.5 rearend support | 10 | terry cronk | 571 | ![]() by slimwud | |
![]() | 10" rear rims? | 1 | terry cronk | 355 | ![]() by terry cronk | |
![]() | Mounting the battery in the trunk area? | 2 | terry cronk | 386 | ![]() by terry cronk | |
![]() | Leaks around a body seam | 1 | CapriceMan78 | 495 | ![]() by Kit1078 | |
![]() | 1978 Impala Exhaust | 3 | tero78 | 830 | ![]() by Kit1078 | |
![]() | Rear end interchange list? 1, 2 | 27 | blacknred79 | 1402 | ![]() by blacknred79 | |
![]() | Wire harness 78 impala | 0 | thotrodder | 489 | ![]() by thotrodder | |
![]() | Anyone put a manual Transmission in a Caprice/Impala? | 9 | Marx3 | 2693 | ![]() by cutlassmike | |
![]() | ignition issues 78 impala | 3 | thotrodder | 481 | ![]() by thotrodder | |
![]() | Heating problems | 0 | Bingt | 402 | ![]() by Bingt | |
![]() | AC Compressors Leaking | 0 | paulboncz | 556 | ![]() by paulboncz | |
![]() | 1979 Impala doors | 14 | denden79 | 1017 | ![]() by terry cronk | |
![]() | 1979 Impala Headlights | 0 | paulboncz | 494 | ![]() by paulboncz | |
![]() | Caprice 1977 - I need your help ! | 7 | stalje | 1693 | ![]() by stalje | |
![]() | ls engine swap | 1 | alusil850 | 580 | ![]() by BrokenBlazerDave | |
![]() | 1978 caprice project | 2 | atherts | 711 | ![]() by atherts | |
![]() | intermittent wipers | 1 | labsrule | 666 | ![]() by Kit1078 | |
![]() | Th200 to TH350 swap | 13 | HeavyChevy77 | 3946 | ![]() by HeavyChevy77 | |
![]() | Q Jet Issues | 22 | HeavyChevy77 | 2675 | ![]() by HeavyChevy77 | |
![]() | big block swap in a 79 impala | 12 | Bill "elvis" | 2980 | ![]() by IMPALA MAN | |
![]() | 1978 Buick Lesabre 2dr Coupe | 0 | churdomega | 540 | ![]() by churdomega | |
![]() | tempmatic controls | 1 | d88force | 793 | ![]() by Kit1078 | |
![]() | 78 Delta Coupe sagging headliner | 17 | Petegresser | 997 | ![]() by Myloth | |
![]() | original 15x6 to 15x8 ? | 7 | alusil850 | 939 | ![]() by GM B-Body Forum | |
![]() | Fuse Diagram | 1 | sosa | 805 | ![]() by Kit1078 | |
![]() | Sbc 350 knocking issue | 3 | HeavyChevy77 | 780 | ![]() by HeavyChevy77 | |
![]() | 1977-79 Sport mirror swap | 0 | 78i6belair | 817 | ![]() by 78i6belair | |
![]() | 305 dies in gear. | 5 | 77LandauCoupe | 823 | ![]() by 77LandauCoupe | |
![]() | Electric fan conversion | 4 | 78i6belair | 1052 | ![]() by 78i6belair | |
![]() | Wet floorboard | 9 | Sean Donica | 1063 | ![]() by JusSko77 | |
![]() | 2nd gen F body steering box swap | 3 | 78i6belair | 1072 | ![]() by Z77impala | |
![]() | 1977-79 4dr sedan RF door window run channel rubber | 2 | 78i6belair | 761 | ![]() by 78i6belair | |
![]() | Top dead center. | 6 | terry cronk | 758 | ![]() by Z77impala | |
![]() | Dual exhaust pre-made | 14 | terry cronk | 2863 | ![]() by Z77impala | |
![]() | Coil spring question | 21 | scy135 | 2303 | ![]() by Z77impala | |
![]() | Setting up a holley stock 350 | 5 | HeavyChevy77 | 1194 | ![]() by HeavyChevy77 | |
![]() | Body mounts | 6 | terry cronk | 2020 | ![]() by terry cronk | |
![]() | automatic column adjustment | 2 | terry cronk | 794 | ![]() by BrokenBlazerDave | |
![]() | 12" rotors 15" wheels | 21 | Myloth | 3618 | ![]() by Fierro51 | |
![]() | PCV valve? | 5 | terry cronk | 732 | ![]() by Fierro51 | |
![]() | Shortened driveshaft. | 2 | terry cronk | 715 | ![]() by terry cronk |
Sort
*For the 77-79's*
Forum | Topics | Posts | Last Posts |
| 5 | 18 | Gas tank upgrade... Sat Nov 24, 2018 3:59 pm Kit1078 ![]() |
| 3 | 6 | THM350 72' Fri Jun 13, 2014 2:41 pm Myloth ![]() |
| 6 | 51 | What rear axle i... Mon Aug 02, 2021 1:04 pm oldspeed442 ![]() |
| 6 | 47 | Heater stopped w... Thu May 21, 2020 12:40 am slimwud ![]() |
| 2 | 14 | Rear Disc Brake ... Tue May 02, 2017 9:52 pm Boogie1468 ![]() |
| 6 | 41 | Biggest tires th... Mon May 25, 2020 3:39 pm slimwud ![]() |
| 1 | 2 | strange options ... Tue Jun 25, 2013 11:22 pm GM B-Body Forum ![]() |
| 1 | 1 | Magazine article... Tue May 27, 2014 2:45 pm Buick_FIN ![]() |
| 3 | 11 | 78 Delta Coupe s... Sat Aug 01, 2020 9:40 pm slimwud ![]() |
| 4 | 18 | 1979 Catalina Sa... Mon Jun 27, 2016 9:39 am 1kcfan! ![]() |
| 10 | 39 | Interior parts... Sun Jul 12, 2020 3:52 am slimwud ![]() |
| 1 | 14 | Floor Pans Sat Apr 09, 2016 3:48 pm Gooched78Caprice ![]() |
| 5 | 35 | Matching the pai... Wed Oct 15, 2014 9:40 pm Sweet Seventy9 ![]() |
| 6 | 28 | 78 caprice wagon... Sun Aug 08, 2021 6:25 pm oldspeed442 ![]() |
| 2 | 9 | Weather strippin... Thu Feb 27, 2014 9:45 pm GM B-Body Forum ![]() |
Users browsing this forum: 0 Registered, 0 Hidden and 1 Guest
Registered Users: None
